하이라이트
Aquila AM69 is based on the high-performing TI AM69 SoC. It offers up to eight Cortex-A72 cores at 2.0 GHz for maximum performance and two Cortex-R5F microcontroller cores. That makes the Aquila AM69 a perfect fit for high-performance edge computing.
The Aquila AM69 is ideal for building cutting-edge AI and computer vision systems. Leverage Toradex tooling on the software side and high-performing NPU, ISP, and VPU units on the hardware side for use cases demanding the highest performance.
Aquila AM69's integrated neural network processing unit (NPU) achieves 32 TOPS for fast inference times, outperforming CPU- and GPU-based solutions in the same power range several times. Toradex provides integration with popular machine learning frameworks, such as TensorFlow.
Aquila is engineered for industrial reliability and a long-lasting lifetime, with 10+ years of continuous operation at maximum temperature. That is also reflected in its rugged board-to-board connector (400 pins), making Aquila AM69 the right choice for mission-critical applications.
With a heterogeneous multicore architecture, Aquila AM69 also offers two ARM Cortex-R5 for complex real-time and safety-critical applications with extremely low latency.
The Aquila AM69 offers a very rich interface, reducing the cost and complexity of the rest of the systems. This makes the Module ideal for Robotics control and high performance gateway.
Highlights include:
- up to 5x Ethernet Interfaces with integrated Switch
- up to 19x CAN interfaces
- up to 11x UARTS
- up to 12x MIPI CSI Cameras
- up to 3x PCIe Gen3
Aquila AM69 is available with a tightly integrated, Torizon Cloud accelerating the development and facilitating the maintenance of your products. Some key features include highly secure and reliable remote updates, fleet monitoring, and remote access.
The Aquila AM69 is part of the Aquila family and pin-to-pin-compatible with the other Aquila SoMs. Designed for industrial reliability and unparalleled performance, Aquila is the perfect fit for demanding applications working in harsh environments.
Aquila Product Family
Ready to Power the Next-Generation of On-Device AI
Aquila AM69 is equipped with a 32 TOPS NPU to power state-of-the-art Artificial Intelligence and Machine Learning applications. Its high-speed camera interfaces also allow multiple 4K camera streams for computer vision applications, with dedicated Image and Video processing units.
Toradex offers support for industry-standard tools and frameworks in the areas of Machine Learning and Computer Vision.
32 TOPS NPU
Low Inference Latency
ISP and VPU
Fast Image and Video Processing
3x Quad-Lane MIPI CSI-2
Up To 12 Full HD Cameras Connected
State of the Art Tooling
Great Developer Experience
Torizon
Torizon makes modern, iterative product development easier by seamlessly integrating hardware, an OS, development tools, remote updates, and fleet monitoring. That makes it a scalable solution for devices requiring high reliability and security.
Torizon accelerates your Aquila AM69 project. The ready and maintained embedded Linux OS with simple tools allows you to focus on your application. Torizon is built with Continuous Delivery in mind, so you can ship early and update iteratively. Secure and Reliable Built-in Remote Updates, Device Monitoring, and Remote access reduces your risk. It lets you detect issues before they get serious, debug devices in the field, and take action. Torizon also makes it easy to comply with new regulations like the EU Cyber Resilience Act.
Get an Overview For Application Developer For Tech LeadsWe wanted to focus our time and engineering resources on developing the application and solving related problems. And Torizon helped us to achieve this goal
Adrian Aschwanden,
운영 체제
Aquila AM69 comes with a free maintained Embedded Linux Operating System. You can either take our Reference Images based on the Yocto Project, or you can use Torizon OS. Torizon OS is also built with the Yocto Project but it is a ready-to-use Embedded Linux distribution. It is configurable for your custom carrier board via the simple to use TorizonCore Builder Tool. This enables developers to concentrate solely on their applications, without having to worry about the underlying operating system and low-level device drivers.
Toradex develops and maintains a Yocto Project-compatible, production-quality Embedded Linux BSP in-house.
특징
CPU Name | TI AM 69 |
CPU Type | Up to 8x Arm Cortex™-A72 |
Microcontroller | 2x Arm Cortex™-R5F |
CPU Clock | 2.0 GHz (A72) 1.0 GHz (R5F) |
RAM | Up to 32GB LPDDR4 (128 Bit) |
Flash | Up to 128GB eMMC |
USB 3.2 | 1x DRD | 1x Host |
Ethernet | 1x Gigabit with AVB (+4 SGMII) |
Wi-Fi | 2.4/5/6 GHz Dual Band 2x2 Wi-Fi 6E (802.11ax) |
Bluetooth | Bluetooth 5.3 |
PCIe | 3x (Gen 3) |
I2C | 9x |
SPI | 7x |
QSPI | 1x |
UART | 11x |
PWM | 12x |
Analog Input | 9x |
SDIO/SD/MMC | 1x |
CAN | 19x |
GPIO | 110x |
JTAG | 1x |
Neural Processing Unit (NPU) | 32 TOPS |
ISP | 2x |
Display Controller | Triple |
2D Acceleration | Yes |
3D Acceleration | Yes |
Video Decoder | 2x |
Video Encoder | 2x |
Display Serial Interface | 2x Quad Lane MIPI DSI |
Display Port | 1x DP 1.4 or 1x eDP 1.4 |
Digital Audio | 2x I2S |
Camera Serial Interface | 3x Quad Lane MIPI CSI-2 (12 Virtual Channels) |
Details | |
Details | |
Details | |
Coming Soon | |
Contact Us | |
Contact Us |
Size | 85 x 60mm |
Power Dissipation | Approx. 5W - 25W |
액세서리
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
- MIPI CSI-2 interface
- M12 lens mount (S-mount)
Videos
Toradex - Aquila Arm Family - A Sneak Peek
로드맵
Hardware Roadmap
- Q2'24
- Q3'24
- Q4'24
- Q1'25
- Q2'25
- In Development
- Sample Production
- Volume Production
