Colibri iMX6ULL
Colibri iMX6ULL is the first Toradex's Computer Module offering on-board Wi-Fi and Bluetooth. The Colibri iMX6ULL is a SODIMM-sized SoM based on NXP i.MX 6ULL application processor, featuring a power-efficient Arm® Cortex-A7 core.
NXP Platinum Partner - Toradex
Colibri iMX6ULL
하이라이트
Powered by NXP i.MX 6ULL
Equipped with NXP i.MX 6ULL SoCs, the Arm Cortex-A7 single core is clocked at 528 MHz, 800 MHz or 900 MHz depending on the configuration of the SoM.
Power-optimized
The NXP i.MX 6ULL SoC is a power-efficient processor which, in addition to being a single-core, allows for a power dissipation of the Toradex SoM in the order of 0.4W to 1.2W, depending on the system load.
High-performance, pre-certified Wi-Fi and Bluetooth
Simplify your design with pre-certified wireless options, counting from the module to the antennas, to increase the predictability of end-device certification processes while enabling significant cost savings. The latest 802.11ac standard and support for multi-antenna setups contribute to a great out-of-the-box end-user experience. These are paired with Bluetooth 5 support to offer state-of-the-art integration for Bluetooth devices.
Toradex Colibri Computer Module Family
Carrier boards designed for the Colibri iMX6ULL are not just compatible between the four Colibri iMX6ULL modules—in fact, they are compatible with the complete Colibri family, including the NXP i.MX 8X, i.MX 7, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
Cost-effective
Colibri iMX6ULL offers a low-cost and power-efficient platform to build a wide range of IoT and embedded devices. It is suitable for headless applications, or static GUIs and light multimedia as low resolution video.
운영 체제
Toradex offers free support and maintenance for Embedded Linux on the NXP i.MX 6ULL processor based Colibri iMX6ULL SoM. This allows system designers to focus on the application instead of focusing on the OS and low-level device drivers.
Torizon Embedded Linux OS
특징
High speed dual-band Wi-Fi
802.11ac 2x2 MU-MIMO
Bluetooth 5
Single core Arm Cortex-A7 @ up to 900MHz
Industrial-grade flash memory - 512MB NAND
Up to 512MB DDR3L RAM
앞면
뒷면
CPU Name NXP i.MX 6ULL
CPU Type 1x Arm Cortex-A7
CPU Clock up to 900 MHz
NEON Yes
L1 Instruction Cache 32KB
L1 Data Cache 32KB
L2 Cache 128KB
RAM Up to 1GB DDR3L (16 Bit)
Flash Up to 4GB eMMC
USB 2.0 1x Host / 1x OTG
Ethernet 10/100 Mbit with IEEE 1588 (+2nd RMII)
Wi-Fi Dual-band 802.11ac 2x2 MU-MIMO
Bluetooth Bluetooth 5
I2C 3x
SPI 3x
UART 8x
IrDA 1x
PWM 8x
GPIO up to 94
Analog Input 8x
SDIO/SD/MMC up to 2x
CAN 2x
JTAG 1x
Display Controller Single
Digital Audio 3x SAI
Parallel RGB 1366 x 768 x 18bpp
Resistive Touch 4-wire
Camera Parallel Interface 1x 8/10/16/24 Bit
Size 67.6 x 36.7 x 6.2 mm
Temperature -40° to +85° C(1)
Power Dissipation 0.4 - 1.2 W
Product Availability 2033+
1 - The Wi-Fi/Bluetooth module featured on the SoM is rated for an operating temperature range of -30°C to +85°C. As this component is not deemed boot-critical, the SoM is still listed as an industrial temperature range product.
최적의 SoM을 선택하는 데 도와주세요
안내해주세요
Colibri iMX6ULL 구성하기
출발해요
Colibri iMX6ULL 1GB
IT
PN: 0062
Colibri iMX6ULL 1GB IT
  • A7
  • 1GB RAM
  • 4GB FLASH
  • -40° to +85° C
Colibri iMX6ULL 512MB
Wi-Fi / Bluetooth IT
PN: 0040
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT
  • A7
  • 512MB RAM
  • 512MB FLASH
  • -40° to +85° C
Wi-Fi / Bluetooth
PN: 0045
  • A7
  • 512MB RAM
  • 512MB FLASH
  • -0° to +70° C
IT
PN: 0044
Colibri iMX6ULL 512MB IT
  • A7
  • 512MB RAM
  • 512MB FLASH
  • -40° to +85° C
Colibri iMX6ULL 256MB
PN: 0036
  • A7
  • 256MB RAM
  • 512MB FLASH
  • 0° to +70° C
자신의 Colibri iMX6ULL 구성하기
Colibri iMX6ULL
1x Arm Cortex™-A7
안내해주세요
Get Started
Colibri iMX6ULL Evaluation Kit
US$490.70
  • One Cortex-A7 800 MHz processor
  • NXP i.MX 6ULL applications processor
  • Parallel RGB or VGA up to 1366 x 768 x 18bpp (via converter)
지금 구매
Colibri iMX6ULL Kit 2
US$311.70
  • Arduino Uno and Raspberry Pi Compatible Pin Headers
지금 구매
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기
Supported Modules
USB 2.0
Ethernet
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
JTAG
Entire Colibri Family
4x Host, 1x OTG/Client
10/100 Mbit
Up to 32 Bit
4x
4x
2x RS232, 1x RS422/485
1x
4x
up to 158
4x
1x 4 Bit
1x
Yes
1x Host / 1x OTG
10/100 Mbit
1x
1x
3x RS232
4x
up to 26
4x
1x 4 Bit (microSD)
2x Host, 1x Client (Shared)
10/100 Mbit
1x
1x
3x /
3x TTL
4x
up to 35
4x
1x 4 Bit (microSD)
10/100 Mbit
1x
1x
2x TTL, 1x USB-UART
4x
up to 39
4x
1x 4 Bit (SD/MMC)
Yes
up to 4x Host
up to 2x 10/100 MBit
1x
1x
1x RS-422, 1x RS-485
up to 4x
up to 24x
up to 4x
1x
Up to 2x
Switches
LEDs
6x
4x
up to 3x
LVDS
HDMI
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
1x Single Channel
1x (Through DVI-I connector)
1x
1x (18 Bit/24 Bit)
Adapter required
4/5-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
1x (18 bit)
Yes
4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (18 bit)
Adapter required
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (Shared with RGB)
1x (18 bit)
Yes
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x
1x
1x
1x
up to 4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
Type Specific Board Connector
USB-to-RS232 Transceiver
RTC on Board
Included Accessory
1x
1x
Mating Power Plug (for X33)
24-way FFC 100mm (for X6)
Yes
1x
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Yes
1x (*Not Assembled) /
1x
Yes
1x
1x
Yes
1x
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-27V DC
5V 5A
3.3V 5A
200 x 200 mm
6-27V DC
5V 5A
3.3V 5A
100 x 72 mm
-20° to 85° C
5V DC +/- 5%
5V (External)
3.3V 3A
74 x 74 mm
-40° to 85° C
5V DC +/- 5%
3.3V 3A
100 x 80 mm
-25° to 85° C
5-36V DC
-40° to 85° C
사용 목적
가격
Minimum Product Commitment
For Evaluation/Development
1 : US$229.00
For End Products
1-99 : US$79.95
>99 : RFQ
2030
For End Products
1-99 : US$33.60
>99 : RFQ
2034+
1 : US$69.90
액세서리
개발자 센터에서 자세히 알아보기
Colibri Fasteners
Resistive Touch Display 7" Parallel
  • No special drivers required
Capacitive Touch Display 7" Parallel
  • Atmel touch driver
LM816 USB WiFi
Carrier Board Accessory Kit
  • Cable length: 100mm
  • Manufacturer: Unictron
  • Manufacturer: Chang Hong
  • Reference: DA-2458-02
생태계
Toradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX6ULL and choose an OS!
Learn More
Easy-to-use Rich Graphical User Interfaces
Colibri iMX6ULL does not have a GPU. Nevertheless, choosing a GUI framework that supports optimized graphics on the CPU is a great choice for a modern UI with moderate level of animations. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Qt
TotalCross
Get started with Totalcross
Industrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX6ULL is a good fit for industrial automation tasks. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
Get started with CODESYS on Toradex SoMs
Matrikon OPC UA
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX6ULL perfectly.
Watch our webinar with BE.services
로드맵
Min. Product Commitment
As per NXP Roadmap
2032
Hardware Roadmap
  • Q2'23
  • Q3'23
  • Q4'23
  • Q1'24
  • Q2'24
0062 Colibri iMX6ULL 1GB IT
0040 Colibri iMX6ULL 512MB WB IT
0045 Colibri iMX6ULL 512MB WB
0044 Colibri iMX6ULL 512MB IT
0036 Colibri iMX6ULL 256MB
  • In Development
  • Sample Production
  • Volume Production
Software Support Status
For latest news release refer
Linux BSP | Torizon OS BSP
Have a Question?
